still thinking holistically were the gels a new type? am allergic to caffeine and more than 1 or 2 coffees gives me a cracker of a headache
It's gotta to be fit. How tight is the chin strap?
Nop not a new type
Dehydration from the very large effort you are putting in would be my thought Gaz.
Do you have plenty to drink afterwards?
The chin strap needs to be fairly tight as I was told recently, should be able to get 2 fingers in, no more...otherwise you may as well not bother as it may just come off and you could end up with an even bigger headache.
I'd blame dehydration/nutrition - most headaches are due to the former. It's also much cooler now, I find cold air gives me a headache due to a history of sinus issues, have you had a cold recently?
Otherwise, why are you wearing the helmet now, when you never have done before?
Hummmmmm , I've still got it this morning , & it seems just as bad as yesterday , would that be indicative of dehydration ? I drank a total of 3-4 l of fluid yesterday afternoon / evening
I worse the helmet yesterday due to some almost 50 mph descents ( seemed the sensible thing to do )
It might seem the sensible thing to do but a little more analysis says its not. First if you hit something at that speed its only about 16 times the design limit of the helmet. Its hardly sensible to use protective equipment to protect that far outside its design envelope. It like using a bullet proof vest to protect against a howitzer round.
Second an EN1078 helmet is designed to absorb 50-70J of impact energy for a medium sized helmet (35-46J for a small helmet, 64-90J for a large helmet). At 50 mph a 300g helmet itself has a kinetic energy of 75J which is added to the impact energy of your head. So a medium or small size helmet will not even protect you from itself at those speeds.
Third, would you have gone at 50mph without a helmet or did you go faster in the belief you were protected when in fact you probably weren't?
