SkipdiverJohn
Deplorable Brexiteer
- London
I have a mid/ late fifties frameset that may be made of A & P Kromo: the painted frame is 1875g/ 4.13 pounds, painted fork is 695g/ 1.53 pounds. That's for dimensions of a 22 inch top tube (centre to centre) and 22inch seat tube (centre to top).
It's lighter than my early 80s 531 frameset. Some have said Kromo frames are consistently lighter than other steels of the time.
Kromo may well be the underlying recipe that resulted in Reynolds 501, which can be a very decent tubeset. As regards unit weight steel is steel. No matter how low or high grade it is it's weight is virtually identical as around 97-98% is iron anyway and the only variation is due to slight differences in the atomic weight of the alloying elements deployed. A Kromo frame will only weigh less than an equivalent Reynolds frame if the tubes were drawn to a thinner gauge. The chemistry differences between mang-moly and cro-moly alloys are too small for this to have any meaningful effect on the unit weight of the steel.
