Appropriate registration numbers on cars...
mustang1
London, UK
A friend of mine has a number plate starting RO though? :scratch: (apparently means it originally came from Reading)
:blush:
I have no clue in that case.
mustang1
London, UK
Both are used in reg numbers
Mmh I found this on auto express (copy pasted):
For example the letters 'I', 'O', 'I' and 'Z' are never seen on number plates because they look too similar to other letters or numbers.27 Jul 2016
Having said that, I have seen letter Z on plates so idk shrugs?
Alex321
South Wales
This is more definitive information from the DVLA
https://assets.publishing.service.g...attachment_data/file/359317/INF104_160914.pdf
O is used in the first two letters (location ID - called "memory tag") - if it is the first, then it is Oxford, it can be the 2nd letter for a variety of places. Q, I, Z are not used in those, although there are existing ones with Q.
The final three characters are random letters, and it doesn't specify any limitations. But if you go to the personalized plates site (linked in the document) and search, it allows Z & O in those, but not Q or I.
O was certainly in use under the old system. We had 671KOH, 20MOF, FOL83L, COX 645C AND GOL912L
At the time, virtually all Birmingham registrations had O in the middle of the three letter set, I think with the exception of OO which was Oxford
presta
I saw this one in Chelmsford once. It was, and apparently still is, a red E-Type convertible, and at the time I saw it it was being driven by a black guy.
Jody
Stubborn git
O and Z are acceptable characters.
I'm not 100% but I think you're right on the letter i
Mike_P
Harrogate
Gunk
Oxford
Pre 2001 Z was only used on Northern Irish plates
With the current format the letter Z only will only feature in the last three letters, it’s not used in the first two letter regional identifier. For example
NH68 PPZ
  • Like
Reactions: DRM
DRM
West Yorks
J, I and Z are commonly used on Northern Irish plates. Not sure about O
J isn’t a Northern Ireland specific letter, but Z and I are, You see loads of GAZ & DAZ reg no’s about, which are for Belfast, I remember my dad having a lorry that came from Northern Ireland that was YOI, it also turned up with a bullet hole in the windscreen!
We had vans at a previous work place from Birmingham, one of them having OOF ***X
