Done it......and got shortest stem possible.Try turning the stem upside down.
Re Sirrus... ..very strange. I want carbon but the Sirrus carbon has a one piece head-set & stem so it is not possible to raise height or shorten stem.....really weird.Try a Sirrus or a Giant Rapid or similar and see how you go? Or there's always an MTB or Dutch style?
How's your core? And your set up? Maybe try stopping for a stretch off the bike every 20 miles or so? Take a rest
Thanks. I did respond but accidentaly put it belowHave a look at the Whyte Montpellier
The giant carbons are hideous
Planet X do a flatbar model in carbon
Or get someone like Pearson or condor to build you one for something a bit special
I found the Roubaix an excellent bike but sadly didnt fix my neck/shoulder problem.Hi Dave, yes as Vickster says I have the Whyte Montpellier and also have just got the full carbon disc braked roubaix.
without knowing you, you mention it could be an age thing, it sounds like it is to do with reach if you are flipping and shortening stems. The Montpellier is a relaxed setup with what I consider to be a fairly long top tube which puts me in a position not to too far away from riding on the hoods on the roubaix. It sounds like you want to be more upright on the bike so you would need to play with the setup on the Montpellier. It also has quite narrow (58cm) bars for a straight bar bike making it feel a little twitchy at first but you soon get used to it.
I have the 2014 Montpellier and have only had the roubaix a week, both full carbon but the roubaix soaks up a lot more road buzz.
The specialized sirrus is a flat bar version of the roubaix using the same frame so worth considering.
Hope this helps Dave, I guess the best thing is to keep trying some out and maybe some professional fit advice.
Hope you get the right bike....![]()
The Montpellier is carbon, unfortunately black. Note, the 2016 is an 11 speedI found the Roubaix an excellent bike but sadly didnt fix my neck/shoulder problem.
Is your Whyte a carbon ??
I'm 69 and back into cycling 3 years....hence my thinking it may be age.
Unfortunately the Sirrus carbon has a weird one piece head set & stem so it cant be shortened or raised.
