Anyone familiar with electrics ?
I have a cargo trilke with a Bafang Fun 8 motor
The battery is fully charged and showing all the correct lights
However when I apply the motor, it shows low battery, The motor then cuts out and the lights are restored to full battery mode. All connections have been checked and the contacts are secure and clean
I assume that this is caused by the load on the motor, so I have checked that all the wheels are running smoothly, there is no problem or resistance when pedaling so I can only assume this is a fault with the motor or circuitry
Returning this to the shop in London for checking is labourious, can anyone suggest what is causing this
Stevec047
Saffron Walden
What type of motor is it. If it has brushes inside next to the armature and they have a larger amount of carbon buildup this can cause excessive heat and poor performance. If it's brushless then I would say that there is a wiring issue. Best to trace the cables from the battery pack through to the speed controller and then on to the motor. Check for any pinched cables shorting against anything metal.
If this fails chances are it will be a sealed component issue such as the speed controller circuit.
I have a knowledge of electrics not from a cycling background but the same principles apply.
U
ufkacbln
Thanks
The motor seems to work OK as when it functions the power and drive are fine
There are no problems with either the wires or contacts
Your answer does however illustrate my problem
An overheating motor would cause both battery and motor issues and explain the cutting out
However the motor works almost immediately after cutting out
I had considered overheating, but the temperature feels no different to my wife's Bionx so I had excluded this
Taking a massive Cargo trike back to London is a hassle
I am hoping to send wheel and battery for them to test on a similar standard setup and diagnose that way
