Anyone else got Corvid-19 Cycle Lanes?
MontyVeda
Apparently, it's to encourage cycling instead of public transport in these unprecedented times, creating a safe zone for cyclists.
The first one appeared on a short stretch of the A6 when lockdown pt 1 was being eased, and had a largely negative reaction from pretty much everyone on the local FB group, with comments such as: it leaves nowhere for drivers to go when an ambulance is flashing its way through the traffic (this is the final stretch to A&E). The lane isn't wide enough to allow one cyclist to overtake another. The cones are too close together, making it tricky to get out of the lane. The cones are designed to pop out when struck, which seems to happen a lot... there's always one laid somewhere in the lane.
Last week, the lanes were extended further, much to the bemusement of the local FB group. I reckon it's just another case of the non-cycling planners deciding what is best for cyclists without actually consulting them.
Ming the Merciless
There is no mercy
Inside my skull
Corvid lanes are nothing to crow about
sheddy
Suffolk
Nothing locally.
If you like any new lanes where you are, drop your councillors a line, just to offset the rabid correspondence from the motorists...
  • Like
Reactions: mjr
Yup. Got them round here. Council imposed them without consultation. Made one road no entry without warning so cars just ignore it. Took massive parking areas away and local traders are irate about loss of business. Nobody uses them.
Our council is somewhere to the left of the Kremlin, and only imposed the lanes because HMG paid for them. Its the first thing they have ever done for cyclists, and they will be removed when the 6 month lifespan expires.
New Brigjton council are already removing theirs.
snorri
NO:boxing::banghead:
I have written to my councillors and received a less than luke -warm response.
They seemed to think that because of covid no works can be carried out at this time. When I told them there was extra money available due to the pandemic they ceased corresponding.
PS I didn't waste time writing to the councillor who had asked me what Active Travel was when he was seeking my vote for his re-elction.
  • Like
Reactions: mjr
Houthakker
A Happy Wanderer
Lancashire coast
Our council seems to have a habit of putting them up in the most pointless areas (on big wide roads where there is plenty of room, then throwing the cyclist back into traffic as soon as the road narrows etc)
Almost seems like they are trying to use the money, but without doing anything that might prove useful and people would want to be come a permanent feature.
Profpointy
That has always been the case with cycle lanes
mjr
[...] had a largely negative reaction from pretty much everyone on the local FB group, with comments such as: it leaves nowhere for drivers to go when an ambulance is flashing its way through the traffic (this is the final stretch to A&E).
They could do what they do on every other narrow road: keep going until they reach a gap in the oncoming traffic, thereby enabling the ambulance to weave between them.
Actually, I have some sympathy for this and say that cycle lanes should be wide enough and sturdy enough for emergency vehicles to use them to bypass motorist jams, like on Blackfriars Road in London - but the drawback there is it would mean a lot more two-way cycle lanes/tracks and the ends would have to have cycle-zebras or equivalent for cyclists in one direction to cross to it and back and British councils/government don't have the guts to install them and enforce them sternly.
So? Use the next lane to overtake when it's clear, like everyone else has to on multilane roads.
Again, I've a bit of sympathy with a similar point: that cycle lanes should be wide enough to allow side-by-side riding so we can talk easily and it at least makes more sense than all those drivers driving around side by side with an empty seat.
Would you rather they were too far apart, allowing drivers to park in the lane? It's a balancing act. I'm pretty sure I could ride a slalom through those posts. I've seen far worse.
Would you rather motorists struck the cyclists first instead? Or that the lane is blocked by cars that have crashed into more solid posts?
At least it looks like those posts haven't got kerb-like mounting blocks under them as used in Norwich (Green Pedalway on Earlham Road IIRC), a lot of which are black and basically become a hazardous stealth speed bump if the post gets knocked off.
The Dept for Transport didn't give local governments enough time to consult cyclists before bidding. It was about 5 weeks from announcement to allocation I think, so maybe 3 weeks for them to submit a bid comprising several projects, so it was whatever the supplied tools spat out combined with anything they may have had on the shelf ready to go (but the shelves were bare at many councils). Doing things quickly is not great but there was a feeling of "strike while the iron is hot" or more "build while the car engines are cold" - although I feel it still wasn't fast enough.
I suspect that the pictured measure is what something like the Rapid Cycling Prioritisation Tool spat out, which seems to favour highly visible interventions on busy arterial routes with nothing much for cycling. The result is often not top of cyclist wishlists but is at least arguable that it makes some sense.
The process for some of these covid travel measures is to install and demonstrate the changes and then consult on what's actually been built to decide whether it is kept. Chris Boardman has spoken out in favour of that process because it allows councils like Manchester to avoid consultations full of NIMBY we-hate-change motorist replies which predict bogeymen that never materialise if the planners and designers are worth their salt.
Also, there are consultations going on now in many places for what to include in the next round of covid travel projects, the Town Fund projects and any Local Cycling and Walking Implementation Plans. Look for them and tell them what's needed - please coordinate with your local CycleNation, Cycling UK and Sustrans Ranger groups if you have any.
mjr
Not always, but far too often. The new watchdog Active Travel England will slap the bottoms (or actually hit them in the motoring budgets) of councils that do the easy bits of building cycleways along simple straight roads and fail to improve the junctions where three-quarters of cyclist injury collisions happen (at least in Norfolk).
The drawback is that Active Travel England isn't active yet and "Streets Ahead" reported that they've heard rumours that it won't start until next year :sad:
mjr
Is that "Nobody uses them" like some newspapers said about the second-generation London Cycle Superhighways?
View: https://www.youtube.com/watch?v=7j7GNPNE9Fs
Local traders almost always overestimate how many of their customers arrive by car and underestimate how many more customers they get if people don't have to do battle with unrestrained motorists to reach them.
They should put a number-plate-reading camera up to enforce the no-entry and collect the idiot tax, or at least stand a marshal there to film them when they've nothing else to do. Maybe publicly ask police and council why they feel the state is so rich and local walker lives are so worthless that they don't need to collect traffic fines?
dodgy
Most, if not all of the ones installed on Wirral to much celebration, have been taken down again already 🤷‍♂️
