All uphill
Still rolling along
- Somerset
So today I took it, by prior arrangement to the LBS.
The side to side play on the crank/BB was confirmed.
Attempts to tighten it proved unsuccessful, so they replaced existing the FSA BB for a new Shimano 105 replacement (the original wasn’t Shimano). That seems to have sorted the play on the BB, although we don’t know how it got that way as they were adamant it wasn’t like that when they checked it before I collected it the last time.
They have re-set the gears and front mech, as the trim wasn’t really working but is now after they adjusted the cable tension. To be fair they replaced the cables for Shimano cables the last time as the ones on the bike were potentially sticking, especially the rear DR cable where it bent quiet acutely as it fed to the rear DR. So they would have needed tightening after bedding in anyway.
They suggested swapping the existing FSA chain for a Shimano chain might quieten things further although not significantly and not worth the expense when the existing chain was fine, even if it wasn’t specifically made for the Shimano mechs. I’ll probably upgrade when this one’s in need of replacement.
I’ll try and take it for a ride tomorrow so will let anyone who is interested know how it goes.
I’d still like a conversion to 1x but if this truly resolves things the urgency will be removed.
Watch this space.
What a performance!
Good on you for sticking with it.
