Chris S
- Birmingham
It seems like a readily available solution. More importantly I won't have a partially used tub of something lying around for years afterwards. (I've still got some T-Cut from the 1990's!)
Vaseline is good for aluminium seatposts on a bike but not much else.It seems like a readily available solution. More importantly I won't have a partially used tub of something lying around for years afterwards. (I've still got some T-Cut from the 1990's!)
Wrong.Vaseline is good for aluminium seatposts on a bike but not much else.
Yes, it's perfect for bike usage. Whack it on.It seems like a readily available solution. More importantly I won't have a partially used tub of something lying around for years afterwards. (I've still got some T-Cut from the 1990's!)
No it's fine as a permanent fix.It would probably be ok as a temporary measure. I remember my mate using Fairy liquid for his hub bearings on his BMX years ago!![]()
It's neither thick, nor gummy.its too thick and gummy use something with less viscosity your restricting your PR's.....![]()
Fairy Liquid? Surely not....No it's fine as a permanent fix.
.... err ....I meant the Vaseline!Fairy Liquid? Surely not....
Now you tell me!.... err ....I meant the Vaseline!
Now you tell me!![]()
