berlinonaut
- Berlin Germany
The spacer between the derailleur and frame is actually the tensioner and the frame?
I don't get exactly what you mean but try my best
: The chain-tensioner has to come out a little bit more than stock. Therefore you need an additional (custom) spacer between the frame and the chain-tensioner/derailleur. You have to make it yourself as it has to be of a special shape, following the shape of the chain-tensioner. Two layers of an old credit card, cut with a scissor, work perfectly fine. Are you dremelling the lip on the 12 tooth? I take it the standard 12 tooth that comes with the hub won't work?
The 12t is the second from the left in that picture:
To make the snap ring, that holds the cogs in place, fit you need to make the inner lower, slightly stepped down part of the 12t cog slightly bigger in circumference by dremeling. It is not much but if you fail to do so said ring won't stay in place. You could however replace it with something smaller so you would not need to dremel on the cog. Either a less thick snap ring or maybe even a cable-tie could work.
If you dremel too much or your donor-cassette has a 12t as the smallest cog it is very likely that the cog will brake apart after a short time of use.
I did not try to use the stock 12t or 16t. For one (if my memory is correct) they are slightly thicker than the ones from the donor cassette and space is the biggest issue with the conversion. Second I preferred to have cogs of the same type and age, thus I carefully selected a cassette that had all the cog-sizes I would need.
To create enough space for the three cogs on the driver you have to get rid of the black inner plastic protection ring that originally sits in between cogs and spokes.
Can a 17 or 18 tooth sprocket work in lieu of the 16?
17t usually works (but not on all rear frames), for 18t you usually have to file a little bit of material off the rear end of the chain-stay tube. It probably depends a little bit from the cogs you use - the higher their teeth are the more likely you get in trouble. Additionally there seems to be a minimal amount of variation in between Brompton rear frames - normally one would not recognize it but with this space-delicate operation you do. Seems to affect ti-frames more than steel frames.
