ukoldschool
Have left my brommie alone for a while, but I'm inkling for some tinkering...
Of late I have been reading up about 6 to 9 speed conversions, that use either expensive thinner titanium gears to get 3 cogs on the rear, or break up a set of cogs to get 3 thin enough to fit on with either a thinner circlip, or garden wire (sounds very 'unusual'...) . They all need a new thinner 10 speed chain.
Heres the Ti parts expensive option:
https://www.sjscycles.co.uk/gear-sp...um-rear-cassette-sprocket-set-w-chain-pusher/
and how it looks mounted up:
https://clevercycles.com/blog/2017/...rompton-the-ti-parts-workshop-triple-cog-kit/
Heres the DIY alternative:
http://thebromptonman.blogspot.com/2018/12/custom-drive-chain-options.html
Now the question I have is has anybody done this? any real world experience? what size sprockets did you use?
If i'm going to attempt this I cant work out if it will be easier to modify the existing left hand up/down gear change to work with a 3rd position (middle I presume) or if its better to purchase a new right hand side 3 speed change and modify that you use on the left?
https://brilliantbikes.co.uk/brompt...3-speed-and-integrated-brake-lever-black.html
Thanks!
Thanks!
