@TheDoctor
This is the last trike build l will be doing for a long while , Mum's health is failing and l have a lot of other tasks that must take priority over hobbies and pleasure.
( might be the last one that l do )
l had some surplus parts at mums that I decided to put to good use .
This is a compact full size. Adult trike that could accommodate a six foot person with ease.
I don't take orders ,It puts me under pressure and takes the fun out of it .
Building the odd trike or two a year allows me to keep the grey matter working when l am not on 3 wheels.
Keeping active also helps to keep the diabetes under control
It will get advertised between September and the end of the year. Once it has had a few shake down rides .The value I would put on it would be around the £425- £450 mark ,
This basically covers all the parts I have used and l hope this thread gives the non engineering types an insight into what goes onto a trike build ( provides an interesting thread generally l hope )
This one being equipped with a rear rack , front and rear lights , mirrors and supplied with a set of diy mudguard stays . It can be upgraded to USS as the stub steering arm has been put on in case . a rear vee brake either as a parking brake or a rear brake can be added and the front brakes could be used from a modified brake lever.
The supplied pedals can be swapped by the user for spd types to eliminate leg suck , a well known problem with feet forward cycling.
Basically it will be advertised as a second hand trike without warranty .
The new parts include 72 spokes for the wheel rebuilds , new 3/16 balls for the 14mm hub conversion , front discs and calipers , 3 chains , brake and gear cables , a pair of steering rose joints , various nuts and bolts and an intermediate guide pulley.
This should make the transmission good for a few thousand miles
Adding the mudguard mounts and arms was an additional idea as someone asked how to fit your own mudguards.
I won't ship and it will be collection only so the new user can get to know how to maintain it themselves .
Any one interested can PM me of course
regards Emma
