Flyingblind
Regular
- Devon
Having sorted my frame thread issue the brake arms fit fine with free movement and no play. So this afternoon I cleaned and greased the bearings, put on a new cassette and tried the rear wheel in the frame only to find the brake pads do not reach the rim. They need to move out another 20mm but the slot is not long enough. The wheel is the correct size, 26 in.
Can you get brake arms with the slot further out or would a different brake type other than V brakes have been fitted?
