Sittingduck said:
How long have you been working on it JTM?
Including unlacing it again (ordered the wrong spokes first time 'round) since Saturday, or thereabouts. Laced hub to rim Sat evening (an hour or so?) first go 'round taking up slack on Sunday (realised it wasn't going to happen because the spokes were too long and unlaced again).
My original calculations were 294mm for non drive side, 292mm for drive side.
I kept the 292s, and laced 10 (9 inside, one outside to hold the hub in position) and ordered 290mm for the drive side. 290s turned up at the bike shop on Wednesday, so spent that evening lacing, and tightening the spokes 'til the nipple driver came out at 4mm.
Spokes were still fairly loose, so went round again with the driver, tightening with a 2mm pin. Then did two turns with the spoke wrench (spokes aren't tight yet, but they have tension in them). It's a 36 spoke wheel, and you have to be methodical (i.e. a turn each spoke, repeat) so it takes a while, especially if you only have half or three quarters of an hour to spare. I find working in these little chunks of time quite good though, helps keep track of where things are up to.
