aerobrain
- Peterborough
I recently bought a Cannondale SuperSix Evo Ultegra (2015) which I absolutely love. However, it had two annoying noises one of which I seem to have found and fixed (took out the top cap gave it a squirt of GT85), but the second is kind of a click when I'm pedalling.
It only happens when I'm seated and generally seems to be when the right hand crank passes somewhere through the 12-3 o'clock position. Doesn't happen all the time, can't replicate it in the stand, although it's pretty consistent when there's some power going through. I've tried testing for play in the cranks and nothing so I don't "think" it's the bottom bracket. The problem is without being able to replicate it in the stand I can't isolate where the noise is coming from.
Just hoping you guys can throw some random ideas at me to try. The LBS where I bought it from are more than happy to take a look, would just be more convenient as it seems to be just a noise rather than an actual issue to sort it myself. Also quite like learning how to solve these sorts of things.
Cheers in advance!
Cheers in advance!
