I'm with Mickle here.
KMC Chains do not recommend degreasers either, as Mickle states the important lubing is with the pin and roller NOT the roller and sprockets.
Degreaser washes-out the lube in the pins/rollers and re-lubing will not easily replace this.
I think I've tried every method over 25 years and Mickle's is probably the simplest and best.
I have experimented wih WD40 after paraffin and then plenty of lube while WD40 still present in the hope that the WD40 thins the lube enough to allow it to penetrate the rollers/pins, the WD40 slowly evaporates leaving lube in the pins area. On appearance it seems to work as there is virtually no oil on the chain in the morning (no its not on the Garage floor) so assume much has dissapeared into the chain. But only have done this when the simple Mickle system is just not enough.
Regularly (after a long ride) I use the Mr Paul Baby-wipe and re-lube approach and then a more intense Mickle-method every couple of weeks.
