An Armoured Bike Lock ?
Wester
Aldi have Armoured bike locks for £5 in their sale . How good are these locks would you recommend them ? how hard /easy is it to cut or break one
Herbie
Aberdeen
I quite value my bike so no way would i use a lock costing 5 quid...each to their own though
RAYMOND
Yorkshire
Theres some good locks on sportspursuit ,about £22 for decent ones.
Worth checking out.
hoopdriver
East Sussex
Unless you are just locking up for a quick dash into a shop, there are no decent locks for £20. If you are talking about home storage, or while you are at work, you need to invest some serious money in a lock, especially if your bike is valuable. A rule of thumb in ten percent of the value. My own bikes are locked up with Pragmasis 16mm chains, very heavy and bolt-cutter resistant - and expensive. Forget £20 locks. You're wasting your time and money.
Cable locks - no. These so caller armoured ones are easy to cut through - there will be a thin cable inside. D-lock only, and used properly.
PpPete
Chandler's Ford
They are ok for nipping into a shop for a pint of milk but not much else
Too heavy for that kind of use IMO
The "armour" will probably mean a scroat needs an 18" bolt-cutter rather than a 14" one, but will still cut the lock in about 5 seconds.... I'd say a plain cable lock at half the weight & bulk would be as much use.
A lot depends on the value of the bike and where you plan to leave it.
I'm with the others here - would not touch it. Bike theft is rather common and chances of getting the bike back are close to, if not, zero... so deterrent is the better option - make your bike look less attractive than one next to it by locking it up with something decent. Even my £300 bike is getting locked up with a decent lock. I can't afford to replace the cheap bike let alone the other one so I only use something that it Gold rated and category 15 (out of 15). Heavy, but in my mind worth it.
