If they are isolated from each other electrically you okay, its when they are not that you run into problems.my alu post has never stuck in the Ti frame
I've posted this a few times but do not use grease in this location it can actually promote corrosion you should use petroleum jelly (Vaseline) as this is chemically inert and helps to stop galvanic corrosion. Id still be tempted to take it out every couple of months though!I don't know if its down to Ti or just luck I've heard of folk having similar problems with other materials and a alloy post; I'm just glad I caught it in time.
As to 26mm bars the only time I've bought them, it was from a bike shop and I forget the brand and specifics on grooves and drop dimensions. I suspect the reason your not getting a reply is because other people experience is similar to mine.
Yeah copaslip would be OK its a b*gger to clean up though, its marketed as high temperature anti seize assembly compound after allHaving followed this thread, and just bought a Van Nicholas, I looked on the Van Nicholas website ... in the FAQ it says that a Ti seatpost will bond itself to a Ti frame in time!!
.... I then e-mailed and asked them about a Van Nicholas alloy seatpost in a Van Nicholas Ti frame ... message came back to ALWAYS use copper grease (sometimes branded as Copaslip) with a Ti frame, whatever metal the seat post is made of (presumably CF wouldn't be a problem?)
Rob
