Bazzer
Setting the controls for the heart of the sun.
 - On the edge of reality
I am 6.4 and I was just under 22 stone two months ago when my 2012 Cannondale CAAD8 arrived (it's a 56cm frame, which I believe is like a 58cm frame with other manufacturers) . I have to run my 23mm tyres at 120psi otherwise I feel too much compression on my rear tyre, which could cause me to get a pinch flat or worse cause damage to the rim of my Madoux RS 3.0 wheels.
I think a good way around the problem of being as heavy as I am, would to use a bigger tyre size which will allow the weight to be spread over a larger surface area. This, IMO should give me more resistance against damaging the rims. As the road surface/quality in Oxford is extremely poor, which is crazy when this city is famous for the sheer number of bike users, as well as being a pretty wealthy city.
If you are seriously considering bigger tyres, be careful how much bigger you go. My Cannondale has 23mm tyres and when the wheels, with the tyres inflated, are dropped and refitted, they have to be wriggled through the brake blocks, even with the cam levers open. If bigger tyres were fitted, say 25mm, I am not sure they would fit easily.
If you like your brakes biting as the levers get near your bar you might have a little more room, but personally I don't.
In the garage there are work arounds such as deflating the tyre before removing and refitting the wheel, but if I am on the side of a road having had a visit from the fairy, I want the tyre fixed, inflated and back on the bike asap, without having to think about the work arounds for my minor modification.
). So if I have fixed a puncture, the last thing I would want to be doing is adjusting the brake cable before continuing my journey.
