Joe24
- Nottingham
That if i put a bigger chainring on the front i will need to either put a new chain on/ make the chain longer or put the new chain ring on the front and chain the gears at the back to be smaller. But that even if i did make the gears lower(if thats right, less teeth) then i would still need to make the chain longer because i dont want the gears to be too small at the top when i go up hills.
I ran out of gears today doing 32mph in a chain-gang and had to just sit behind the back trying to slipstream and keep up.
Got harder near the end, couldn't keep my legs going fast enough to keep pressure on.
So am i right or do i just make no sence?
Cheers
Got harder near the end, couldn't keep my legs going fast enough to keep pressure on.So am i right or do i just make no sence?
Cheers
what gear ratio were you in when you were 'running out' at 32mph?
The other people still had about 2-3 gears left.
