Aldi Cycle Day
soulful dog
Glasgow
I replaced my cheap brake pads with a pair of Kool Stop pads and they have lasted a lot longer.... at £12.99 not sure they'll last 4 times as long though, so might give them a try. Also, I see their bike computer this year is a bit more expensive (& includes a heart monitor), but the one I bought last year has just recently stopped working. I liked it while it worked but disappointed it didn't last longer (I only had it on the bike for about 6 months), so I've splashed out and replaced it with a Sigma computer. Fingers crossed it lasts a bit longer....
Got this in their email newsletter this morning. I am considering the glasses, the blurb states tha they come with different lenses so maybe I can pick up a pair of clear ones for night riding. The cycle computer caught my eye, I am in need on one and wireless one should be ideal if it works alright, a 3 year guarantee should hopefully see me through any mechanical problems. Could get a set of brake pads for when it comes to replace the canti ones on my tourer, worth a punt at that price.
Tyke
I had two of the same computers with NR in the past they both failed after about 2 years but that's not bad for the price.
ohnovino
Large Member
Liverpool
I bought one of those computers and ended up returning it. It kept freezing and wouldn't respond to button presses.
I'll probably give the brake pads a go, though.
Cletus Van Damme
Previously known as Cheesney Hawks
Ok cheers mate :thumbsup:
Sheffield_Tiger
The glasses are not bad
The cycle carriers are crap - BUT only as crap as any other strap-on carrier. I f you don't want the expense of a towbar or roof bars then the Aldi is as good as any other
PompeyBill
Am off down Aldi later today (handily it's just beside the local Asda, where I need to go anyway) and will pick up some of those glasses. Would finish off my cycling gear quite nicely, and make it look as though I am an expert cycler, and not the chubby beginner I actually am :thumbsup:
al-fresco
Growing older but not up...
Shropshire
Sadly, the acquisition of cycling gear never finishes
Cubist
Still wavin'
Ovver 'thill
where would one actually spray GT-85?
It's a vital part of any cyclist's toolkit IMO! GT85 is a light lube that dries to leave a PTFE (Teflon) protective layer. It contains a solvent which means it's also good to use wet as a light cleaner.
I use it to spray onto the cassette when I've cleaned it to get rid of any remaining water. I use it to lubricate the jockey wheels and sprung sections of the mechs. I also use it sprayed direct onto a really gritty chain and wiped off before employing the "Mickle Method".
My MTB is matt black anodised, and a wipe down of the frame tubing with GT85 makes it look and smell wonderful. It leaves a semi-gloss finish on cable outers and brake hoses.
I also use a squirt on the saddle clamp, the Seatclamp QR, the brake lever pivots, and the straw gets into the shifters to drive out any moisture after a wet ride or hose wash. I also spray it onto the pedal mechanisms
In fact, apart from the brakes and rotors every metal surface on the bike will benefit.
