Advice please - Swapping between workstations
Alex321
South Wales
I've just had an idea - my monitor, mouse, keyboard are all plugged into the dock. The laptop connects through one USB-C cable. So If i get a small tower PC then I can simply unplug the USB-C from the laptop and insert it into the PC tower? I guess I'll have to make sure that the PC Tower has a suitable USB-C slot, or I may have to buy an adpator but that's fine.
I'll only be running Reaper music recording software, so won't be a huge load on it and I'll only need the one monitor
Most pre-built current towers have one USB-C port, on the front.
figbat
Former slippery scientist
You may want one of the monitors plugged into both the hub and the computer (using one of the additional inputs on the monitor) as it may throw a wobble if it can't detect a main display on the desktop. All should work.
This is how my home office is set up. I then swap the input source on the monitor to switch between laptop and desktop.
Alex321
South Wales
And mine is the same.
Work laptop plugged in to display port 1 on the monitor, home desktop into display port 2.
Usually only one is switched on at once, and it automatically takes the feed from that. If both are switched on, it is a button on the bottom of the monitor to switch between them.
november4
If you want to have them both on at the same time, each with a screen, then use a program like mousewithoutborders to use the 1x keyboard and mouse for both systems, the mouse just scrolls across
icowden
Surrey
Thank you. I don't use the laptop as a laptop - it's mounted on a cradle and I use an external mouse and keyboard. I don't have enough room on my desk for two sets of everything which is why I wondered if there was some magic switching-dock where you could choose which source you want to use.
Yes there is.
It's called a KVM switch.
https://amzn.eu/d/8ZhzWU0
Check your inputs and outputs to make sure you have the right switch. I use this one:-
https://amzn.eu/d/fjO5b5H
It has a little button on the front - you just push it to swap computers. Mouse keyboard and monitors (and any usb extenders) just re-map to the current device. Mine even has a little extension button on a cable so you don't have to have the main KVM on your desk - you can stick it the extension button to the bottom of your desk out of sight, or somewhere convenient.
BigSid
Hungerford
At work I used to have 2 PCs with a KVM switch. To change between the computers the KVM switch was controlled by the keyboard; CTRL, CTRL, then 1 or 2 to select which computer I needed to use.
