Advice please on a trusted local bike shop....
Venod
Eh up
Yorkshire
This is the nearest to you @Marazzi Mick
http://www.jscycleshack.com/
If you find something at a good price on the net they will try and match it, they are also very good mechanics, its run by James Wagner and John Tanner (ex pro and Olympic Rider) they are the j's in the name.
There is also Kendell Cycles on Oxford Street in Castleford again good mechanics, and Gary Proud the owner is regarded as one of the best wheel builders around.
http://www.kendellcycles.co.uk/
Marazzi Mick
Marazzi Mick
Marazzi Mick
Marazzi Mick
I think it is Campagnolo and the thing is pristine, the owner estimated it had done less than 20 miles. I don’t want to mess things up initially so I’m going to get some training in weather permitting and ask advice from a bike shop in Knottingley I have been recommended on the forum.
All very useful info for a novice - I’m impressed!
Venod
Eh up
Yorkshire
Thanks for that, I’m going to call in at the Knottingley shop. There is nothing wrong at the moment but I need to buy a pump and ask about a service.
Thanks pal
When replying to posts there is no need to post twice, just click the quote button in the post you want to reply to, then in your new post click insert quote and you can type below it.
Hope you get the pump and service you require.
Nonethewiser
I'm a new returnee to cycling, Mick, but I'm just not keen on paying for the servicing of a push bike and I'm going to learn how to get on and service my bike myself. Cycles are, after all, relatively simple machines or so I'm told. No doubt I'll find some tasks more difficult than I anticipated but I think it really is worth having a crack at owner maintenance, what better way is there to get to know your machine?
MrPie
Telling it like it is since 1971
Perth, Australia
Sa-weeet ride!
Bike fixin & fettlin is relatively straight forward -saved myself a fortune over the years by doing my own work. Its also very satisfying and can get you out of a tight spot when you are out in the open road. The only extra tool you’ll need for campagnolo is a torx wrench - it’s used for adjusting brake blocks and afixing the rear mech to the hangar. All the other servicing spanners & Allen keys are standard. YouTube and GCN website are fab.
youngoldbloke
Campag cassette lockring tool? Bottom bracket tool. I've got Veloce on one of the bikes and the only Torx bolts are on the shifter clamps. Everything else is standard Allen bolts. It's quite an old version though, knowing Campagnolo the current specs are likely to be quite different.
