Tyres pumped - let's see if they're still 7bar in the morning
7 bar
is that just to see if they hold pressure, what size tyres ? one of the attractions of tubeless is the ability to run lower pressures for comfort.Tyres pumped - let's see if they're still 7bar in the morning
is that just to see if they hold pressure, what size tyres ? one of the attractions of tubeless is the ability to run lower pressures for comfort........7 bar in the morning.
7 baris that just to see if they hold pressure, what size tyres ? one of the attractions of tubeless is the ability to run lower pressures for comfort.
…it's wot it said on the tyres as max. (Mavic Yksium Elite 25). The Vittoria Rubinos on one of my other bikes run at 10!I run tubeless Continental GP 5000 on carbon wheels. 7 bar is very high. I run at 5.5 which some would consider high.
MAX, not MIN!…it's wot it said on the tyres as max.
I used to run 25s with tubes about 80psi, I run 30mm tubeless at 60 psi, I would try 25mm at 70 psi, I weigh 12.5 stones.…it's wot it said on the tyres as max. (Mavic Yksium Elite 25). The Vittoria Rubinos on one of my other bikes run at 10!
I have a friend who runs exactly the same. He keeps encouraging me to do the same.Agree, here 65 front and 70 rear PSI on 28mm Conti 5k
As @ColinJ said this is the maximum recommended pressure. I've never heard anyone speak of using 10 bar (145psi). Most people I ride with would be below 7 (100) and in the region of 5.5-6.0 (80-90).…it's wot it said on the tyres as max. (Mavic Yksium Elite 25). The Vittoria Rubinos on one of my other bikes run at 10!
I may try it but I have this thing about high pressures helping to reduce punctures.
That's an interesting thought. I'm visiting my LBS this afternoon. I'll ask the question.apart from the increased ride comfort i assume a lower pressure gives a better chance for the sealant to work
Me neither. But hello Charlie!
@CharlieB - https://road.cc/content/feature/how-do-you-choose-right-tubeless-tyre-pressure-268427Thank you all. Most helpful to an ignoramus.
Wheels and glop installed with very little issue (nothing on Mavic website to suggest amount), but 35ml as read from Trek site used. It's really stinky, isn't it?
Tyres pumped - let's see if they're still 7bar in the morning.
We'll cross the bridge of changing tyres when we get to it, and then I'll be back for suggestions.
Cheers again, C
