Lovacott
Anyway, I seemed OK for a while but the rocky, soil path got steeper and never seemed to end. I was breathing harder than I ever have before and eventually I kind of conked out. I'm not that unfit as I do a bit of wall climbing and I'm not overweight.
Before I started cycle commuting up and down Devon hills to work back in May, I'd spent six weeks of furlough doing 20 miles per day on the local estuary cycle path. By week six, I was hitting speeds I'd never dreamed possible and I was doing it with ease.
However, on my first attempt at the hills, there were none over 12.5 degrees which I could get more than a third of the way up.
My first commute took me nearly 100 minutes.
But every day after, I managed to get a little bit further up each hill and within two weeks, there were only two which I couldn't manage in the lowest gear. A month in, and I was doing all of them without having to resort to "granny gear".
Eight months later and I can't remember the last time I used the small ring on the front? My commute now takes me 53 minutes.
Hills are not all about strength and fitness anyway. A good 50% comes down to technique and familiarity with each hill.
How hard do you go on the approach, how quickly you want to get up the hill, which gear do you select before you start your ascent and when do you change gear on the way up? Where to conserve energy, where to go full pelt?
The only way to answer the above is to repeat each hill until you get it right. Soon, you will have built up a map in your head with every gear change and effort level labelled onto that map.
