Ian H
Ancient randonneur
BrumJim said:Woah.... Tyre bulging and coming away from the rim whilst trying to pump up the tube fully? Sounds like a major problem there. Defective tyre needs to be replaced FOC - not fit for purpose. And that will almost certainly be the cause of the punctures.
I've seen it happen with old, non-hook-beaded rims and cheap steel ones. Otherwise it might be that the tyre isn't seated properly - perhaps the valve hasn't been pushed up inside the tyre after fitting. Undo the the valve ring and push the valve in. Retighten the ring only after the tyre's inflated.
) is to deflate your tyres once a week, and then carefully look them over and with a pair of tweezers or a sharp point, carefully prise out any bits of glass or grit embedded in the tyre. If left in, those bits can easily work their way through to the inner tube.
why the GP4's were so expensive!
