Origamist
mike.pembo said:I dont think its put me off cycling in built up areas but its learning what to look / listen out for and how to best react. Watching it back Ive learnt that even though Im in primary I didnt use it to manouver correctly to make myself safe - instead I had a spurt of fury which may lead to a loss of control - so this is definatly something I need to work on. However since using primary when the situation dictates I have had much fewer close overtakes.
Thanks for the advice everyone, I really appreciate it.
Mike, it seems you're already pretty savvy. Taking primary in multi-lane situations will not prevent close overtakes, but it will make them less frequent. Expect to receive "punishment overtakes" (from a minority) if you eschew the cycle lane or ride in primary as some motorists take exception to this behaviour - it's invariably accompanied by a beep, hand gesture or verbals...
The key point is that you cannot physically command the lane in the same manner as a motorised vehicle - this means it is crucial not to rely solely on the preventative effectiveness of taking primary, it must be allied with vigilance (shoulder checks) if possible - negotiation (eye contact), or possibly a controlled wobble/deviation (to throw a bit of unpredictability into the mix), but most importantly, a contingeny plan. If you sense an imminent overtake, you want to be taking evasive action before the vehicle is alongside - there's no point having a four/five foot buffer if you're not going to use it. That said, the greater the speed differentials, the greater the problems...
As for remonstrating/abusing drivers, I stopped bothering (well, almost) a decade ago.
