Sellyb
- Sayers Common, Sussex
I have entered my first more serious sportive, and I was wondering if someone could give me some advice for the day. These may sound like real novice questions, but I like to be prepared.
a) How do the timing chips work assuming that's what people are usually given? Do you just wear them around your neck and they beep on and off at the start and finish, or is manual intervention required?
b) How does a woman usually answer the call of nature if travelling on the bike alone e.g. where to leave the bike at feed station (if that's where the loo is)? Maybe it's possible with the exercise that a call of nature is not always required? Please don't laugh, women worry about these things! :-)
c) Re feed stations, I'm guessing you have to pay for food, or not? Can you fill up your fluids here too? d) Also to complete in a good time, do people not usually stop at all the feed stations?
If there is any other etiquette to note, this would be appreciated e.g over-taking, joining group correctly etc.
Thank you in anticipation. For info if it helps, I'm aiming for 65 miles to begin with, which is probably peanuts to a lot of you, but I only took up cycling again in March, so hopefully one day I will be up for the challenge of more.
can be good to talk to people as you go too! Makes the miles less work for some reason.
