Racing roadkill
You'd be right as well.Often you uneed to feel inside the tyre for stuck objects etc and I cant see a novice being able to get a really tight tyre back on without removing the wheel.
Often? Punctures are rare enough anyway with modern resistant tyres and ones where the cause isn't obvious is even rarer, so that's a small subset of a rare event. I don't let such rarities deprive me of easier cycling.Often you uneed to feel inside the tyre for stuck objects etc
I can't see why they'd use a really tight tyre, nor why it's any easier to put a tyre on a wheel that's falling around.and I cant see a novice being able to get a really tight tyre back on without removing the wheel.
I'd put it on the grass rather than scuff it on a hard floor but the basic principle is sound. Where do you place the bike aside, then? Does it lie down or do you scuff the hoods and saddle by putting it upside down? There's rarely a handy bench or fence to hang the saddle from, especially on typical commuting routes.It's a good job that bike above is a piece of junk. It will be sporting an additional set of scuffs - watch it scrape the floor. My bikes are too nice for that abuse.
Sorry, but dropping the back wheel off, placing the bike aside and working on the back wheel with minimum use of levers if far better.
YMMV. Derailleurs spend their lives dangling in everyday crud as well as the excellent salty grinding pastes of winter roads, all exposed and so vulnerable to knocks and falls that they're now generally attached on sacrificial hangers.Road salt corroded dérailleur - never happens.
So... scuffing the side of the bike against a wall and resting the bike "gently" on a small vital part?I lean my bike upright against a wall or a tree. Back end rests gently on the chain
I feel the vast majority remove the rear wheel because they either don't realise there's a more practical alternative and/or they've been lied to and told it's easier or even necessary.(the vast majority of cyclists remove the rear wheel - you just do it differently)
No but my derailleur bikes don't get ridden as much. I've seen a few rear mechs come adrift on group rides, without sign of evidence poor maintenance, but I don't know that they were corrosion. As I opined before, it's a more fragile design. I know derailleurs aren't too unreliable for most uses, but they are less reliable than gear hubs, contrary to the claim I was rejecting.If you've had a rear mech corrode, then I'd question your maintenance.
Well you dangler fans stop piling into every time someone asks about hub gear bikes then and coming out with the same tired old myths.Let's give it a rest now jesus. This is about a new bike.
tired old myths.
If he's got any senseDo you think Larry1706 might have packed up and gone to another forum?
I think @mjr needs to accept he is in the minority here.
Maybe to a forum where people actually offer useful advice on hub gears instead of the same old prejudices. :-(If he's got any sense
...if one considers removing/refitting a cable and a few extra axle washers as "much more faffing"If you need to take a wheel off, then they are much more faffing, [...]
