Plus an extra 10% off with a PX code.
But if too small.. shame.
https://www.planetx.co.uk/i/q/ZXPXTIX1/planet-x-spitfire-titanium-road-frameset
Found this frameset too which may be bigger although the site is not showing me the options. I have emailed them directly to see
All of them...they have the full range in their shop (not open Sundays)
I don’t have a Condor ...yet...as I have enough bikes right now having got my Ti finally after a year procrastinating![]()
The Spitfire frame is not disc brake enabled.
To be honest, I've not ridden the Ti that much yet for several reasons not related to the bike (most recently knee surgery)Vickster - I have just noticed the list of your current bikes. Can you comment on the feel and ride of each frame material? From the photo of your bike I don't think you have the weight issue I have but would be great to understand the difference you have experienced.
. Spa built me wheels with 32 spokes
I also far prefer the ride of the steel or Ti, carbon just feels a bit dead and plasticky with no give (the Ti has a springy quality)Can’t answer technically but I could see a clear difference in welding neatness between the Spa Elan and Sabbath AR1 which I ended up with. Price difference £3-400 I thinkI think I am keener on Ti as I want to make this bike ‘The Bike’ if you know what I mean.
My next question is what is the difference between a £599 Planet X frame, a £1,350 Kinesis Racelite and the likes of Litespeed et al coming in at £3,000 upwards.
Is it to do with quality of material, quality of construction (because it seems Ti frames are solid unless crashed), or lightness (I.e. optimising thinner tubing in parts of the frame).
I bought TI frame from planet X, The Hurricane.
Don't let one bad experience put you off. problems with bikes can happen whichever the supplier and manufacturer.
In fact just checking, The Hurricane frame is now available for £599, which is silly money for a Ti frame. XLarge in stock too
but after my experience I warn any 'larger' riders of buying a cheap carbon bike
I spent a few quid on the Etape, wasn't sure about spending that much, but the smile whilst having a test ride on the Evoke convinced me
Lovely bikes if you can spend that much, although they still have the Evoke ex-demo bike in 60cm for £2699
https://shop.enigmabikes.com/collections/factory-outlet/products/evoke-disc-60cm-ultegra-r8000-buildBicycles by Design will do a Swallow frameset for around 1800 (from memory of a friends last year), fit a Campy Potenza groupset for around 1100 and a set of decent 36/32 wheels... you'll be around the 4k mark once you add bars, stem, saddle and post...plus assembly costs if you want someone else to do the spannering.... that's a lot for a bike, but it's what my perfect Brompton has cost me, and the perfect bike is perfect.... the downside is the screaming from the waller regions, the upside is you will have a bike that will always fit you, at your size and weight a bike that's a couple of pounds heavier than your old Allez isnt hoing to notice vs perfect fit.If your going to splash the cash on a bike to last have you considered a custom built frame either steel or Ti ?
Out of interest where did the 2 frames break and was there an obvious incident such as hitting a pothole ?
