Advice for being able to see in the rain
Fiona R
Formerly known as Cranky Knee Girl
N Somerset
I'd be in the nearest ditch without glasses, well I wouldn't, as I'd have not found my cycling kit. Blind as a bat.
As for steaming up - occasionally wash your glasses with washing up liquid, and just rinse them off under the tap - works for my cycling glasses. - My normal glasses aren't suitable for cycling - too small !
I have serious rain/night time issues with sight, and the two combined are scary. In monsoons no glasses are better than drenched/foggy glasses. I literally inch along when I am caught out. I can't tolerate lenses either.
Even with good sight riding along dark unlit lanes at night can be a nightmare, especially if a car comes towards you with it's headlights on .
It is fine when the car lights up your pathway but then you are plunged into darkness as it passes you by .
A good memory of where the road was is essential .
wajc
I'm pretty sure no-one in this thread said to wear it under a helmet. Doing so is a bad idea and against several helmet makers' warnings because it would enable the helmet to slide around, fail to protect the top of the head and dig into the side of the head or possibly the neck. I wear a cap or peaked hood but no helmet. Wear a helmet with a peak or visor if you use a helmet but please don't wear one dangerously with a cap underneath. I'd hate to hear you've been injured by it.
I don't believe that there is any issue with wearing a cycling specific cap underneath a helmet. Most helmets have enough adjustment to allow for a proper fit with a thin cap or buff underneath.
From a different thread but makes a good point about the difference between a baseball cap and a cycling cap though, so I'd never advocate wearing a baseball cap under a helmet
Cycling helmets are different from baseball caps in that they are shaped to grip your head and the peak is much smaller. Oh and they don't have a button on top.
Plenty to choose from here and all described as under helmet caps - if there was a real danger then I'm pretty sure they would not be using that as a description
https://www.rosebikes.co.uk/clothing/cycling-clothing/headwear/underhelmet-caps
They can help to keep you cool, warm, prevent sunburn, prevent insect stings if caught in helmet, keep rain out of eyes, keep sweat out of eyes.
Seems OK for this cyclist as well !
Chris Froome wearing cap under helmet
mjr
Believe what you like but I'd check your helmet manual before wearing one!
Is that because you also believe "Crash" Froome is famous for never doing anything reckless like taking a hand off the steering at speed downhill?
wajc
I have a Giro helmet
Here is a link to a Giro cap on their website
Giro SPF30 Ultralight Cap
and in the description
ENJOY WARM SUNNY RIDES WITH THE SPF ULTRALIGHT CAP. IT HELPS TO WICK MOISTURE, PROVIDES UPF30+ RATING WITH EXCELLENT BREATHABILITY, AND THE SMART SEAM HELPS ALLEVIATE PRESSURE POINTS FROM YOUR HELMET.
Apologies for the capitals - it's a cut and paste job. My bold as well, I'd missed this benefit from my earlier list.
Giro helmet fitting instructions
I've had a look through the fitting instructions. I can see no statement regarding the wearing of a cap under a helmet being advised against, and as they sell their own under helmet caps then I'll make my decision based on that.
I'll accept that other manufacturers may differ in their advice but until I've seen some scientific evidence to the contrary I'll continue to wear caps under my helmet in the winter for warmth and in the summer to keep the sweat out of my eyes.
mjr
Nor can I, because it's a broken link(!)
Whereas I'd rather see them testing it and showing that a cap doesn't render the retention system. I bet no-one's tested hammering nails into the helmet at intervals but that doesn't mean it's safe!
wajc
LOL
Try this
https://www.rei.com/media/72d7fa17-6462-4d59-bc1c-f06b77515fac
I think you're seeing danger where it doesn't exist - if you're that worried about things I'd advise not getting on the bike in the first place :-)
GetFatty
I treated myself to some vented Oakleys this year as I've spent a fortune looking for the right cycling shields over the year. My main issue has been fogging up and the Oakleys have sorted that. The hydrophonic (?) capability that was advertised also seems to work as I've worn them in the rain with no issues either.
Helmet thread is over that way < - give it a rest.
Dogtrousers
Lefty tighty. Get it righty.
FWIW the Specialized helmet manual says "WARNING: Do not wear anything underneath your helmet such as a cap, hood, bundled hair, headphones, barrettes* as the helmet may loosen or come off."
Whether this is sound practical advice or just legal arse-covering I don't know. Other comments on this are indeed off topic for this thread and should indeed be addressed to the Helmet Dungeon.
* I had to look this up. It's American for hair clip. https://en.wikipedia.org/wiki/Barrette
Please direct that to the post introducing helmets here and contradicting the likes of Trek's helmet manual but I'll end here for now.
Oh FFS - this thread is about how to help in rain with a glasses wearer, not weather (deliberate spelling mistake ^_^) a cap will void the protection/warranty blah blah - please go and rant somewhere else about helmets, this is about seeing in the rain.
RegG
Nottingham
I find cold rain whilst MTB'ing, especially just after a climb, quite hard to see as my glasses will also steam up from heat, but there isn't enough 'speed' to keep them clear. Not so clever when you start a technical downhill right after the climb.
