Can't argue with the advice given already and well done for taking the plunge.
As far as the quitting smoking is concerned this is more my field than cycling and I think someone has already mentioned realistic goals. Setting yourself a fixed goal may not necessarily be the best approach as it can be demoralising if you get to 2 weeks and find you are not where you hoped to be. I have worked with hundreds of smokers in the past and every experience is different so there are no diffinative time markers (some have no problems at all while others go through a whole range!)
I would start 'practicing' with your bike ASAP and take it gently. Remember when you get up Good Friday to have no smoking related stuff near you to get in the way. Some people like to have a hidden stash but personally I don't hold with this as it is always too much of a temptation. If you do cough and wheeze as has been mentioned just remember it is only the body finally being able to do the job it was designed to do, and this will all depend on how much, how long, how efficiently you have smoked.
Good luck with it all, you sound pretty determined to stick at it, good on you
