Fifelad
- Carnock,Fife
Right only a slight adjustment needed here folks new cables put in by LBS so everything fine apart from the usual cable stretch. I have a triple at the front, so although it is changing, it is not so slick and is sometimes missing the middle ring and changing from big to granny ring and missing middle ring. cables just need a slight tightening in tension I would say. Remind me what direction again to turn the barrel adjuster and what chain ring I should be in while doing this....memory like a sieve ! I could nip it into LBS I know, but want to use the bike ASAP !
