Adjusting tension in clipless pedals?
Sniper68
It'll be Reyt.
Sheffield
I had the end of a Look Keo cleat snap off due to wear on a Sportive in Wales a few years ago.I take cleat covers out now if I plan a coffee/beer stop as plastic cleats and Tarmac are not good friends:angry:
I still replace them every year or before once they look scuffed and ragged around the edges.
simongt
Norwich
The newer Shimano M525 has a much easier visual for adjusting the tension that the older M515, so makes things less guestimating. :thumbsup:
rogerzilla
Most clipless pedals have varying amounts of tension. Some are made for casual users with very low tension and are very easy to unclip.
Other more "serious" pedals have greater default tension.
This is true. A couple of extremes: Shimano Click'R pedals are meant to be easy for beginners and release very easily. Shimano Dura-Ace SPD-SL pedals hang on for grim death even at their minimum tension, which is where I have them.
I am happy with everyman M520 or M540 SPDs as they come out of the box. The original M737s were quite a bit tighter - complicated in that case by the fact that they have two moving jaws per side, and entry is a bit different to modern SPDs.
Chap sur le velo
@acknee
johnnyb47
Wales
I went clip less last year for the first time. What a revelation. From personal experience i would slacken them off to the max and see how you go. That's what I did and have never felt the need to tighten them
semakof
Thats exactly what I did. After falling off my bicycle twice, I slacken them to the maximum and it has been easy unclipping them. In fact, I noticed one was too tight which was responsible for my inability to unclip quickly.
Sharky
Kent
There should be approximately one-half inch of movement in the chain up and down at a point halfway between the front and rear sprockets.
Just to add to this, for fixed & SS chains. Make sure that you check the slack as described above, when the chainring is in the "tight" position. Chainrings are never completly circular and checking the slack when the chainring is in the "slack" position, could lead to a very tight chain on parts of the rotation.
