silk186
- Reading, Berkshire
I just purchase a GT avalanche 3.0 and I'm tuning it up myself.
I've adjusted the disc brakes. I can't lock the tires but the bike can stop in 1-2m.
The brakes and tension have both been adjusted.
The next to adjust was the gear set. The rear gears work well, I can cycle true gears smoothly.
The front gears are the problem. After adjusting the front derailed my thumb is sore from the amount of force required to shift up in gears. I haven't found a guide that explains how to adjust the tension required to shift.
Secondly, the chain feels loose. What I mean is that the chain doesn't appear to have much tension. It's bouncy and it I'm shifting from and rear gears at the same time it can get stuck, almost tangled. Should I do some type of adjustment to the rear derailleur to tighten things up?
The bike is 2010 and came in good condition. The derailleurs appear to be in good condition.
