wam68
Doesn't instill confidence.
What happens when the adapter mounting clips fail? I don't want to know
Theres a difference between that and the earlier links. Yours is bolted on, I'd suggest it's more comparable to a post mount adaptor. I'd still not do it and stick to whatever the frame was designed for though.
I guess I was robbed as I spent considerably more than £2 on this disc conversion bracket for my bike.
Do not all brakes rely on clamping?Relying on clamping with a braking component just seems a really bad idea.
Whats wrong with sideways if enough elevationDo not all brakes rely on clamping?
I tend to agree with some of the negative comments in the above posts, but would like to evaluate it for myself, which can't be done properly by viewing a photograph.
Some things that don't seem like a good idea turn out to be fine. Can you imagine the derision with which the first heavier-than-air flying machine was greeted, for example? Or the helicopter ejector-seat... no, hang-on, that was a bad idea! :-)
I can live with the £1.70 research budget, BTW.
Steve
Kamov Ka-50Do not all brakes rely on clamping?
Steve
It's the clamping onto the seat stay I don't like, but for £1.70? - why not.It is the world's first operational helicopter with a rescue ejection system, which allows the pilot to escape at all altitudes and speeds. The K-37-800 rocket-assisted ejection system is manufactured by the Zvezda Research and Production Enterprise Joint Stock Company in the Moscow region
"...investigations indicated that the source of the crash was due to a "malfunction of the ejector (seat) mechanism" which caused it to activate involuntarily."
The ones in the links are a clamp arrangement around the stay - liable to move under braking and be difficult to align without rubbing so would need adjusting frequently. Relying on clamping with a braking component just seems a really bad idea.
