The tyre is down, the wheel is stuckLet the tyre down to unjam the wheel, get the wheel in place, THEN pump the tyre up?
I've tried to undo the quick release on one side and the nut on the other side but they are both stuckWhat is it stuck on?, some sort of lawyers lips?
I've tried that but its stuck completely!Hard to see what is stuck but sometimes just flipping the bike back round the right way onto its wheels can help the wheel naturally settle into the dropouts.
Both the bolt at one end and the skewer at the other end are stuckAre you able to take the bolt off the end of the skewer? (or is that stuck?)
If you have a quick link on chain, would it help taking the chain off? (maybe it's adding more tension to the wheel/rear mech).
Clutching at straws here as you can tell!
The brake caliper is not in the way, the mech is out the way and the chain is on the smallest ringDon't understand why the lever or nut won't come off. And it's not the brake caliper blocking removal ?
Where's the chain in all of this ? Are you moving the mech out of the way ?
