FrankCrank
Old layabout
Okay folks, thought I'd entertain you with a rebuild of this old timer of '79 vintage. No surprise to most it's a rebadged Raleigh Stowaway. Only noticeable difference is the crankset design and a few stickers. Acquired the bike on my recent visit back there
I fully dismantled it and brought it here in my luggage. As well as folding, the frame comes apart just by undoing a bolt, so makes for easy transportation.
As an aside, my airline of choice is EvaAir - they offer a generous 2x23kg check-in baggage allowance, even for cattle class.
Anyways, my plan is to put the bike back together, servicing as I go, and a few mods along the way. So, hope you can join me on this journey, and please do ask any questions at each stage, if you need more detail.
Thought I'd start with the wheels. As standard, these bikes have 451mm wheels with steel rims, but in the States they get 406 as standard. Both are known as 20" wheels just to confuse things. I'll be converting to 406 with alloy rims. This gives greater tyre and tube choice, but more importantly better braking.
I'm gonna keep the original front hub - it's a clever piece of engineering in my opinion
It has one fixed cone, the other is adjustable, but no lock-nuts. The chrome has no rust spots at all, amazing after 40 plus years. It's stamped with 'Sturmey Archer', and has a real quality feel to it, way better than some of the newer wheels that have come my way recently. The cones have a shoulder on them which locates into the 'keyhole' of the dropouts, holding it firmly in place, even without tightening the nuts. I think this is unique to Raleigh and its rebadged variants of the period. Discovered one side had 10 bearings, the other 9, so popped an extra one in along with fresh grease.
I already had a donor 28h wheel, so that's good for a rim and spokes, and I've got some brass nipples instead of the rubbish steel ones. The donor wheel had different hub dimensions - the flanges were closer together and the spoke hole circumference was bigger. Luckily, these two cancel each other out from a spoke length perspective, so the spokes were the perfect size for this new hub/rim combo
Here's the wheel on the Park Tools truing stand (ha ha)
And completed
And completed
