On what?What’s your advice on that?
Hilly stuffOn what?
Roads? Rigid forked bike with the correct gearing for your level of fitness (probably a triple or compact double chainset), flat or dropped handlebars, light as possibleHilly stuff
No the bikes you've linked are mountain bikes so not the best for road riding, more for light off roadOk thanks but also the difference is the color right and the bike is best on road and what else?
Because it'll be heavier than a roadbike, bouncy due to the suspension (even with locked) and draggy on fat knobbly tyres. If you want to ride on roads, a road bike designed for roads and not mountain biking is usually a better optionNo? It you can go on flat road,City road and climbing so how is it bad for road riding? So how is it bad for road riding?
What does that mean?Well I want a mountain bike since it goes light speed with shifter
On the suspension forks? it stops them depressing, more rigidForget it but what does lock do?
Use on roads, that's why road bikes have rigid forks not suspension. You only need suspension off road and even then it's debatable (MTBs can also have rigid forks)When should I use them and where
