I cross referenced power demand, speed and gradient years ago using a Test Automation motorcycle chassis dynamometer.
It was £120,000 worth of VCA ( Vehicle Certification Agency ) approved 'rolling road' to measure emissions on motorbikes.
I praise PowerCalc to be quite accurate.
Those who don't have the luxury of such a piece of equipment are fortunate today to have PowerCalc on the CTC website. PowerCalc was not available in 1998 and MachineHead was developing his programms. He too, is commendably accurate.
When you have a spreadsheet of your gears, speed and the cadence required to achieve those speeds in each gear, you can use it as a look-up table while playing with PowerCalc.
If there is a gradient on your route which is 'tough', you can change the gears numbers on your look-up spreadsheet to find a more suitable ratio for the climb.
