migrantwing
I am wanting to run a sealed system as there are a lot of country lanes in my area meaning potholes, mud and water. I arrived at the idea of buying some PTFE liner and some rubber grub seals/boots and some lined caps and nosed ferrules to make the system as sealed as I can possibly get.
My question is; roughly, how much cable travel is there when changing from a 34t front to a 50t, and also a through the range of a12-30t 10 speed cassette? What I'm saying is, I know that the changes are done via tension, less or more depending on a higher or lower gear but, from a fixed point on the cable, how much does the cable tighten and take up slack and how much is actually pulled (in a forward or backward motion), resulting in travel?
I understand that this question may not have a definitive answer, if it can be answered at all, but any thoughts would be appreciated, at the very least, interesting.
TIA
TIA
