mootaineer
- London
I've had a quick look through the threads...
What pumps do you carry when you ride/commute?
The best for me so far have been the Quicker Pro and one of the Topeak ones (I can't remember the name).
Right now I carry the Quicker Pro because it's a bit smaller but still gets high pressures. The pressure gauge doesn't seem to work at all so I'm constantly pumping, then pressing the tyre down to check if it's inflated enough
So for me the perfect pump would:
1) be reasonably compact (fit in a bar bag)
2) inflate to high psi/bar (not necessarily 160psi but at least able to inflate to pressures that are high enough)
3) have a hose so that I don't damage the valve stem while I'm pumping
4) have a screw-on thread so that I don't damage the valve stem when I remove the nozzle
Has anyone found the perfect pump:?:
At home I use a JoeBlow trackpump which works really well (apart from not liking the lack of screw-on thread).
The Topeak was good but I broke the plastic frame mount and it doesn't fit in my barbag where I keep all of my tools when riding
