Tony Raynor
Need for steeds
- Newcastle/Patrington Haven
Depends on the material of the seat post. If it's alloy then it's probably going to be cut out. Coke is no good for steel against alloy as the resulting corrosion of the alloy does not dissolve under acidic conditions. Force isn't that much better as the areas that corrode act like spot welds.
If it's a steel seat post then you have a good chance if you can get the acid to soak the area to break the rust down.
Good luck with removal
