LordoftheTeapot
I'll wait. Thank you early 'warning' domtyler, I'm sure it will be worth it.
ajevans said:[1] So Linux isn't suitable for you due to your reliance on one software suite. You can't then use this as an argument to say that it is not an option for other people.
[2] You get a lot of updates as Linux package managers don't just update the OS itself but every piece of software on the system. With Windows it updates only the OS. You have to manually update each application you use. Furthermore certain Linux distrubutions not only update the software and OS but also upgrade it, for instance my distribution will evolve overtime into new releases so no waiting for new releases and no faffing about with install disks once new releases arrive. As soon as something new has been invented and tested thoroughly it'll be installed with minimal fuss.
In summary you can't just dismiss it as an option especially when your knowledge of it is limited.
barq said:I had a quick look and I can't find it (post it up here if you can). But those are fairly reasonable specs to be thinking about. Probably worth comparing with equivalent offerings from Dell and so on.
a .
davidwalton said:...
If or when Linux becomes a real option, I will consider it. Until then, and for many who are not willing to take chance on Linux, OSX is where it is.
ajevans said:The thing is Linux is a real option for many. OSX isn't.
The reason is that it is free to try and will work on almost any hardware. It's also secure and stable, which is why it is used by the likes of the IBM, Google, and the National Security Agency.
I'd heartily recommend OSX for people who are clueless with computers as they'll struggle to break it. But OSX. as for Linux and Windows is not for everybody.
davidwalton said:.... It SEEMS that Linux is not supported by the software houses that sell for OSX and Windows????
ajevans said:It is also true that OSX is not supported by most of the software houses that sell for Windows.
However in both cases there are plenty of alternatives available that (with the exception for certain specialist uses which are not required for most consumers) aptly fit the bill.
OSX like Linux like Windows is not the solution to everybodies needs.
You seem to be arguing with someone else. I never suggested this.
You'll note that I've also only talked about your majority, average user. And asked why they should spend any more. Seeing as your answer doesn't relate to the question, I can conclude that you can offer no reason why they should.
Again, I have never said that I would buy, or recommend buying, a bike that cost £80.
Though second hand of course is a different matter.
The right £400 computer is not the cheapest you can buy. But it's all that most people need.
David, David, David. We've never been talking about what you need. Read the thread again.
I have little interest in what you are saying because you are suggesting that because you have very specific needs, then everyone else should buy the same computer as you.
You're mixing up the argument about what's best (and the jury is still out on that one as well) with the one about what people actually need.
So, Apple is the Burberry of the computer industry.
That's us all agreed then.
Read the £200 pound comment again. You'll see I was talking about second-hand pcs. It's a separate discussion.
Don't scrabble around trying to make claims by assumption about what I'm saying despite me making myself very clear (the £80 bike bit). It makes you look silly.
If you think that then you either don't actually know much about computers, or are just trying to drag something over to your side of the argument, as with your regular use of 'probably'.
No I'm not. Read the thread again.
I'm not talking about what you need. Stop getting defensive man.
It'll do far more than that.
If they're prepared to spend money that they don't have to.
Nope.
Accept something that wasn't part of the discussion? Why?
