andy_wrx
I'm converting my Winter bike from 8sp to 9sp, have all the bits except the chain hasn't turned-up yet, but I'm getting twitchily impatient to start.
Could I as a temporary thing get away with running a 9sp Shimano (compatible) drivetrain with an 8sp chain ?
(new SRAM 9sp cassette, existing not-very-worn SRAM PC58 chain, 105 f&r mechs and chainset which are currently happily running with this 8sp chain, used Ultegra 9sp shifters from a friend)
I'm assuming that whilst the cog-to-cog distance on the cassette is less and the correct 9sp chain correspondingly a bit narrower, there will be a bit of leeway to allow for the derailleurs not being set-up 100% perfectly, or for things going out of adjustment or wearing, minor cable-stretch, etc.
Twould only be a temporary thing until the 9sp chain arrives next week, so
if I was careful to make sure the derailleurs were set-up absolutely spot-on, will I get away with it or should I restrain my impatience till next weekend ?
(if it turns-out the part-worn chain jumps on the new cassette, that's different issue...)
