crazyjoe101
- London
Hello CC,
I am planning a bike build, it will most likely be around a Kinesis Crosslight Pro6 cyclocross frame, aimed for all year road use. Since this bike will be using disc brakes, I'd like to use through axle wheels, however the frame is not designed to accept them, it accepts standard 9mm front and 10mm rear quick release axles.
My question is this:
Is there any reason that hubs using 9mm front and 10mm rear through axles could not be used with my frame?
The hubs I have in mind are these Hope Pro2 Evos: Front, Rear
Thanks in advance.
Thanks in advance.
