6001 Bearing - Actual Size
Hello,
This is the first time I've got the prospect of replacing cartridge bearings. I could do with a bit of insight from someone whos used to dealing with them, if somone would kindly indulge me.
I've removed said bearings from the 20" (406) wheels on a Thule child trailer. Unfortunately, the old bearings are not stamped or etched. They measure up fairly close to a 6001 bearing, which would be 12mm bore, 28mm outer diametre, 8mm width.
These bearings actually measure :
  • 12.76 mm bore (actually, that's the axle. I get a slightly smaller measurement from the bore but I think that's down to not being able to quite fully extend the my verniers due to the curvature of the bore)
  • 28.6 mm outer diametre
  • 8 mm width (the only measurement that's spot on)
Now, they are quite worn - not that I'd think it would make that much difference. Are these normalish actual measurements for a 6001 or are they non-standard bearings?
I have ordered some stainless steel 6001s, but rather than cross my fingers and hope for the best, I figured I should consulte the hive mind before writing off a set of hubs.
Thanks.
wafter
Oxford
The dims sound a bit out to be the nominal metric values you suggest; could be an imperial alternative..?
Might be worth searching for data sheets from bearing manufacturers - two that spring to mind being SKF and NTN..
PedallingNowhereSlowly
That's a good shout.
In imperial:
Bore size: 0.5" (0.50236"; ≈ 1/2")
Outer diameter: 1 1/8"
8mm: 5/16"
On edit, these maybe?
On second edit: After measuring several times again, the axle is about 12.65 mm which is within 2/1000 of half an inch.
@wafter I think you've just saved me from an expensive mistake. Thank you.
raleighnut
In imperial:
8mm: 5/16"
They look a better bet, I was gonna say imperial sized bearing but was beaten to it
Profpointy
Hello,
Thanks.
To echo what others have said 12.7mm is exactly 1/2"
Tenkaykev
Poole
Cheapest I can find those SKF bearings is £25 each.
Oofta. These [ebay link] are a bit cheaper - not stainless steel though.
Oof indeed! I used to purchase bearings when I was working. We used a lot, from miniature to Ginormous. It's worth visiting your local bearing factors and asking there. They carry a fair amount of stock, our trade discount on SKF, NSK, FAG was 80%.
With plenty of grease the 'regular' steel bearings should be good - Any bearing (ss included) won't be much good if water gets inside!
I've no doubt these will be plenty good enough for a bike trailer that's probably only going to be used a handful of times before the sprog outgrows it and I sell it on.
Tenkaykev
Poole
We almost always specified " 2RS " for our stock bearings ( 2 RS = 2 rubber coated shields ). That way we could flip one or both shields out if necessary, or to clean out and repack with a specialist grease. What always amazed me was how little grease was in the bearings, even the larger ones ( palm of your hand size etc ), to the extent that I thought " this can't be right " I did query this with the SKF rep once, and he sent me some in house research that showed the vast majority of premature bearing failure was over greasing.
Fastpedaller
Norfolk
Maybe over-greasing is a problem with fast-rotating bearings, but in the 'hostile' environment and slow rotation bicycle parts are subject to the opposite may be true?
