Wankelschrauben
Good point !!!!!
What gear was he wearing as a matter of interest?
I was wearing a tight fitting black T-Shirt, brightly coloured patterened shorts and clipless shoes.
Good point !!!!!
You won't. Voltage is too low, and you'd be adhereing an LCD screen to a set of sunglasses. Just requires a little skill, a magnifying glass and some finesse.
Ok done a little bit of reading and I confirmed what I thought. Although I didn't write it very wellI'm not sure I understand what you are saying.
My experience suggests that speed is calculated from the rear wheel speed, sit on a turbo and spin with gps turned on, speed will be displayed but no distance information. Unles you turn gps off, then you get speed and distance.
The max speeds on garmin connect are not quite right. Where it gets the data from I don't know. If you find that you have a ride which says you did a max speed of 100mph and then put that tcx file into another price of software (e.g. Ascent) it shows you a different max speed.
So looking at the data and checking it with another piece of software should verify if it was a glitch.
I don't think I have had an issue with max speed whilst using the gsc10. I suspect the issue is down to the errors you sometimes get with gps readings and it jumping out of place.
Ah yes, I'll have to double check. Garmin don't make this easy eh.
A very fast cadence. But the way that people have dismissed that +40mph is not possible because they can't do it and pro's can. Must mean I can't spin that fast.
Does it say by how much the garmin will be out (on average?). Also isn't the implication there is an inherent problem with the Garmin?
As far as im aware it's only a problem with garmin connect and the max speed. And it's only an issue if you had a gps blimp whilst cycling and you are not using the gsc10 unit.Does it say by how much the garmin will be out (on average?). Also isn't the implication there is an inherent problem with the Garmin?
34-11. And I did do this in a bit of racingGearing you were in please, 170 RPM is something that sprinters do in the closing metres.
Not neccessarily, just their post-processing software. Its been long established there are better 3rd party software suites out there for reviewing the data they log.
34-11. And I did do this in a bit of racing![]()
