New job, weather, family, etc all making things slow, but pretty much got everything stripped from the frame.
Cranks & Bottom bracket fixed cup was a bloody nightmare. Crank puller started shredding threads on crank. Finally resorted to some bearing pullers, an old 8-or-9mm socket (to save the thread on the spindle) , lots of patience, some swearing and a good bit of force.
BB Fixed cup finally came off (quite easily in fact) with a BB adjustable cup spanner, an M10 100m bolt, M10 nut, 4 x M10 large washers and a good push (no hammer needed)
Only thing left on the frame are the fork top & bottom fixed cups. First question. should i remove these, or mask off and paint round? If I try and remove will i likely wreck them? should (could) i get new ones? Decisions, decisions - all advise welcome
You can see i have started taking the old paint off, and frame underneath is in pretty good nick👍
Wheels have had it. Too far pitted to be polished out, so looks like 2 new 27 x 1 1/4 will be needed - there are a few around on Amazon & eBay. Plus of course tyres, chain, brakes, cables, ... That slight pay rise with the new job is gone already
Only other major item is freewheel. it looks like an Atom 77 (it is an Atom 7-something).
Easy to get off when i got hold of the right tool (Park Tool FR-4). But it is not coming apart for anyone. Been using chain whips to try separate the cogs (those should be standard anti-clockwise to undo, correct?) and they are not moving.
lock ring is equally as frozen (that's a reverse thread, clockwise to undo, correct?). There is years of muck, chain oil, etc caked on (been cleaned a number of times already, yet more gunge comes off every time)
So, thoughts and advise please?
Thanks in advance for any advice, thoughts, ...
- I keep trying to dismantle, clean, replace ball bearings, etc?
- I get a replacement Atom-77, there are a few milling around on eBay?
- I got something more modern to replace it?
