Davidc
- Somerset UK
There's far to much macho bullshit written about gearing.
Well said.
Well said.
Yep, people should be encourage to buy bikes they can ride not bikes they need to push
I wonder why it's called a push bike
Macho has it's uses though... got a 10 min climb up 8.3% gradient with an ave speed of around 9mph. You're aiming for a climbing cadence around 60rpm do you go for 38/19 or 54/28? & which one puts the fear of god into people?those "macho" type comments are from the guys that haven't cycled proper hills, therefore can be ignored![]()
I'll go for 54/28 -38/19 and 54/28 are nearly the same, so i would choose 38/19 for better chainline.
I'll go for 54/28 -
* I've yet to see benefits to keeping the chain line 'good'.
* better efficiency - turbo & crank power metering shows me I get higher % of my crank power to the rear wheel on the 54/28 combo than the 38/19
* slightly lower gear for a little more head room for the steeper sections of the climb
* If things get really steep an instant 42% drop in gear & as I've got the cadence band to deal with that boy does it work well
* if in a competitive environment is a psychological advantage.
I don't get this you ride differently thing, as even after 90 miles in the Alps I'm still climbing in the same way I did when I started the ride, I'm just pushing out less power.
proper hill - plenty of them in sw uk, wales, northern borders. i'd say a mile long hill over 15%, or 10 mile hill of 10% are proper hills.
