28mm P Proof Tyre
Mallory
Okay my plan to use Marathon + tyres has failed. They are just too wide to fit on my rims. Although the wider 35mm studded Winters fit fine
So I am after other suggestions?? Must have good p protection and 28mm wide
potsy
Rambler
My Armchair
:unsure: :scratch:
Are you sure you're not just having trouble fitting them?
Thy are notoriously difficult 1st time round.
M
Mallory
Difficult!!! You mean absolute f###### B####### to fit
The bead is too wide. I did managed once to seat them without the tube. The tyre just want to pop off both sides of the rim every time.
potsy
Rambler
My Armchair
:biggrin: Yep, they are a challenge.
There's a vid on line where you cable tie the tyre on in a couple of places to make it much easier, once they.ve been on a while they do soften up a bit and go on better next time :thumbsup:
They will fit better once the tube is in there with a bit of air pressure. You aren't wrong about the difficulty though!
M
Mallory
They're going back to Evans!!! I've fitted these before on other wheels with no issues like this. Rather run the risk of a P with a tyre that I can at least change easily.
MattHB
Proud Daddy
Conti 4 seasons?
MattHB
Proud Daddy
just put my new conti 4 seasons on today. wow what a great tyre. amazingly the 28 is only just over 25mm wide (@90psi), so not sure how theyre sizing them! ive read in cycling plus they over size them as the 25mm is only about 23.5mm.
wiggle have them on offer as well with tubes at the moment @ c.£70 which is a bargain.
MrGrumpy
Huge Member
Fly Fifer
+1. Durano + also available in 28mm, and they're as tough as old boots too.
ahem they aint that hard ^_^ got a deflation tonight fortunately not far from the house and it was a small thorn right through the tyre and the blue liner inbetween! In fairness I do take them over some rough ground! Oh and I ride 23mm size which may or may not make a difference.
StuAff
Silencing his legs regularly
Portsmouth
My experiences have been rather more positive. But results obviously vary! :smile:
Jdratcliffe
Redhill, Surrey
Matt thatas very interesting i have a set of 4 seasons on and brought them "23mm" so wonder how thick they really are.. :dry:
